  • Leon Cuzzilla Friend
    #181889
    When I create my custom html modules to place on particular pages. The content shows line breaks when I press enter to leave a line between paragraphs but on the live site there is no line space and all the paragraphs run into one. Why is it doing this in the html?
    Thanks in advance.
    Hi imatilda,
    Please try to open content of that article with HTML view, add </br> tag if needed.
    If problem still persists, try to switch default editor in Global Configuration to None.
    #471776
    Thanks for your reply. I know you can put the <br /> tag in but I want someone to go in and use the WYSIWYG formatting. I’m using JCE editor and I’ve uninstalled and reinstalled. Tiny MCE does the same. It doesn’t happen when placing content in articles only custom html module. Is there something I put in the css for module paragraphs do you think?
    #471852
    I worked it out eventually. I assigned a module class suffix to my modules then gave made paragragh this custommodulename p{ display: block;} in the css and this worked! Thanks for looking at it for me though!:)
    Glad you solved it 😀
This topic contains 5 replies, has 2 voices, and was last updated by  Saguaros 12 years, 1 month ago.
