  • INSERM UMS33 Friend
    #850334
    I use the theme Plato. In JA ACM, there is the block [Container] Tabs. Can we customize it to place the tabs at the top of the block (horizontal position).
    Thank you for your response
    Adresse de Livraison:
    You can try with JA ACM – Container Tabs – Style 2 as in Uber template: http://uber.demo.joomlart.com/index.php/blocks/container-tabs
    Check out this guide for how to use this style 2 in JA Platon: https://www.joomlart.com/documentation/joomla-templates/uber-template/acm-configuration#acm-other-template
    These are different templates with different styling so these are basis steps to use ACM in different template and , of course, you will need to customise style to have it looks as you wish.
    INSERM UMS33 Friend
    #870931
    As you suggested, I’ve installed JA ACM Uber in the Template folder.
    I create a folder in Uber template in which I introduced ACM file. I did not put directly into the template Platon to avoid conflicts because there are common issues between the two ACM.
    So I created a new ACM "practical information" by selecting the type "info contact: Style 2" from ACM-Uber. The problem is that the card does not support the full width of the block (block set in blue). I feel that I have a block to another block. And information in the blue box is poorly positioned in the card. I can not pretend in your documentation https://www.joomlart.com/documentation/joomla-templates/uber-template/acm-configuration#contract-type.
    I also another big problem with the position of the blocks when I blocks positioning settings "responsive layout". I opened another post for this.
    Can help me solve these problems?
    thank you very much
    I replied you in that topic, kindly check.
This topic contains 3 replies, has 2 voices, and was last updated by  Saguaros 8 years, 11 months ago.
