June 14, 2016 at 11:21 am #940439
Hello, and sorry for bother once again! I’m actually trying to place a custom module (With text inside only) inside an article. I want to be able to add different modules for every article. I’m attaching an image to show where I’d like it to be placed.
Also, I want a module to be visible in multiple articles, so far I can only see " {loadmodule mod_custom,Custom_Noord_Pricing}", but nothing else is appearing on the page. I’ve tried different positions but I’ve been unlucky until now.
Thank you in advance!
Saguaros ModeratorSaguaros
June 15, 2016 at 8:21 am #940727Hi
Does this module show in article in default Joomla template?
You can try to switch default template to a standard template of Joomla and see how it goes.
June 15, 2016 at 8:24 am #940728No, for some reason is not showing in the default, I will check with another style, but I do need it to work with default.
June 15, 2016 at 11:06 am #940763Ok, My bad, I was using an event instead. I’ve checked and there’s no plugin to load those modules inside the "Events". Do you know a way to achieve that?
Edit: Ok I did, was using the wrong position!
June 16, 2016 at 2:15 am #940972Is it ok now?
June 16, 2016 at 7:33 am #941016Yes thank you! Joomla has too many options, it’s hard to handle for newbies like me.
June 16, 2016 at 8:55 am #941042You can gain it days by days, if you find any difficulty, just raise your question, community will help you out.
AuthorPostsViewing 7 posts - 1 through 7 (of 7 total)This topic contains 6 replies, has 2 voices, and was last updated by Saguaros 8 years, 3 months ago.
Customized module position issue
