  • Pankaj Sharma Moderator
    #1007837
    Open /css/custom.css file in the A Sugite template folder
    Use this code make the off canvas sidebar bg to white
    .t3-off-canvas {
        background: #151515!important;
    Change the color code as per needs.
    For slideshow
    .ja-masthead .container {
        padding-top: 0px;
        padding-bottom: 0px;
    Hope it helps
    mickman Friend
    #1007842
    Whow! Pankaj, you are my hero! 😀
    And for the "Dropdown" . Is it dropdown? I don´t know. Look at the attachment please.
    1. dropdown
    #1007847
    Use below code in custom.css file for dropdown
    .t3-off-canvas .t3-off-canvas-body .dropdown-menu {
        background: #fff!important;
    mickman Friend
    #1007850
    Well….. now I learned a lot in seconds. Thank you very much 🙂
This topic contains 4 replies, has 2 voices, and was last updated by  mickman 7 years, 11 months ago.
The topic ‘Customizing, please help with a few tipps’ is closed to new replies.
