  • tangierc Friend
    #161608
    I can’t seem to get the default them to be what I want. I want the light-brown.
    I went to the Global tab and selected the light-brown them for the profile override, then emptied my browser cache and tried it in another browser
    – same result. The sites loads in the dark blue.
    Why isn’t this working? It’s not even working from the cpanel on the front end anymore.
    Someone please provide a solution. I have a lot depending on this site working.
    YOu try following to this http://www.joomlart.com/forums/topic/solution-for-the-error-in-saving-template-configuration/
    then change the color and check this issue again
This topic contains 2 replies, has 2 voices, and was last updated by  Saguaros 13 years, 9 months ago.
