  • stevencoleman75 Friend
    #208666
    I am experiencing a issue trying to install demo sites on my virtual hosted server using XAMPP 3.2.1. (windows 8, &8.1) This is not limited to just this template but having the issue with multiply templates. I have got it working on another machine with the same installation, but am experience this issue on two other machines..
    I put in all the info on the setup screens for the demo, and it starts the installation, but I can leave it and it never finishes.
    Has somebody else experience this issue and can point me in the right direction to fix it.
    Steven Coleman
    Ninja Lead Moderator
    #577324
    It’s pretty hard to suggest correctly the solution in this case, but you can check with steps below
    + Try to download and install xampp for windows with default setting
    + Download Joomla package from joomla core and install it on xampp
    + Download JA Fixel from download page and check out this documentation for how to install quickstart installation here
    Hope it helps
This topic contains 2 replies, has 2 voices, and was last updated by  Ninja Lead 9 years, 5 months ago.
