  • goepf Friend
    #121976
    I’m new to Joomla and see this smaller problem. On the frontpage only the first item is full width. All the following texts like News are in two columns. Where can I change this to have the same style like in the Bellatrix sample site?
    Thanks for a quick tipp.
    Göpf
    Menalto Friend
    #226897
    Go to Menu>Main Menu>Home and set columns to 1 instead of 2 on the right side,there you have many settings you can choose from to make the frontpage look the way you want
    goepf Friend
    #227024
    Have still to learn a lot, But your asnwer opend my eayes. Will contact you later
    Göpf
This topic contains 3 replies, has 2 voices, and was last updated by  goepf 17 years, 4 months ago.
