Viewing 6 posts - 16 through 21 (of 21 total)
  • cybernun Friend
    #433447
    ITS A PATH PROBLEM
    but I’m embarrassed to say I don’t know what it should be: 😮
    background: url(../images/stories/bio/forma_transparent1.png) no-repeat;
    http://siteground281.com/~donnafor/draft/
    cybernun Friend
    #433448
    SORRY SORRY
    YOUR POSTS CAME IN LATE
    WILL READY CAREFULLY AND FOLLOW
    promise
    cybernun Friend
    #433456
    IT ALL WORKS!!!!
    You are fab. :-*:-*:-*:-*
    Thank you so much. I am saving all of the documentation for future use. Just great.
    This is what it looks like now:
    May I ask one final thing?
    I have posted in the Ja Sulphur forum but none is answering not can i find the answer within the posts. I am working on a Ja Sulphur template but the Ja Slideshow 2 images will not link to respective pages.
    This is the code that they tell you to use but it does not work and I already tried the full path too:
    <p>Vestibulum mauris ut sed laoreet Nulla et molestie nisl. Ridiculus eu id pretium</p>
    This is the site:
    http://siteground270.com/~morriso5/draft
    jesflow Friend
    #433457
    the link does work so for the slideshow, only suggestion is read, read, read. know that can be any number of things. there’s no text or link or anything so is probably in the module configuration somewhere.
    cybernun Friend
    #433458
    OOPS
    The articles on the other pages are now too high!
    http://siteground281.com/~donnafor/draft/index.php/work
    Is there a way to only have the HOME page article exactly where it is? This is the code:
    /* Content Main */
    #ja-contentwrap {
    border: 0 px solid #DDD;
    background: url(../images/forma_transparent1.png) repeat scroll 0 0 transparent;
    margin: -150px 0 20px;
    padding: 20px 20px 0;
    border-image: initial;
    jesflow Friend
    #433461
    Probably so. I’d go on and make separate post about that one…
This topic contains 21 replies, has 2 voices, and was last updated by  jesflow 12 years, 11 months ago.
