  • ar2solutions Friend
    #144051
    Hi all,
    http://www.team1778.com
    We’ll, one of my weak points are SEO/SEF url’s. I use SH404SEF and had no problems in the past but this one, i can’t fix.
    For some reason, if you go under “MTHS Robotics” and click “mentors or accomp or/and courses”
    you’ll receive this in the url: http://team1778.com/?task=ARTICLE-NAME.htm
    Where the “ARTICLE-NAME” is replaced with the article name 🙂
    I wanted to know if any users expereinced this problem and if so, please do tell the solution.
    Its only having problems under the “MTHS Robotics.” item menu I tried creating a new menu item but with no avail.
    Thanks all in advance,
    Best Regards,
    Ar2Solutions
    Anonymous Moderator
    #316909
    Hi ar2solutions
    I could not find this issue in your website.
    Did you fix this issue?
    If not, please kindly let me in detail how to see this issue?
    ar2solutions Friend
    #316910
    I Have NOT Fixed yet
    the issue is when the user clicks on “Mentors” under MTHS ROBOTICS menu item. (top menu)
    the url i get is http://team1778.com/?task=team-mentors.htm and it routes me to the home page.
    How can i fix this url so it routes me to the http://www.team1778.com/content/team-mentors.htm ??
    hope you understand 🙂
    bennitos Friend
    #316915
    Please try again with the Team mentors menu item now it should be working now.
    It looked like your category “content” was causing that 404sef did not create the url’s correctly.
    I have created a new category “newcontent” and moved the team mentor article in there and now it works.
    So try to move the articles from the “content” category to the “newcontent” or a different one, and clear the 404sef cache. This should solve your problem.
    <em>@ar2solutions 144010 wrote:</em><blockquote>I Have NOT Fixed yet
    hope you understand :)</blockquote>
    ar2solutions Friend
    #316919
    Yes, thats seems to have solved the problem!
    Thanks mate.
    Recap:
    1) I deleted the category that all those articles were saved under and created a new category.
    2) switched all articles from the 1st cat. to the 2nd.
    3) Cleared out my Cache from sh404sef by disabling then re-enabling.
    BAM!!!
    it worked!
    Thanks again
This topic contains 5 replies, has 3 voices, and was last updated by  ar2solutions 15 years, 2 months ago.
