robandyuk Friend
robandyuk
- June 2007
May 29, 2008 at 10:45 pm #129062is there any reason why on the front page of my site that I am developing the prices when discounted in VM DONT show up in red with a line through them on both the latest product module or the ja vm product slider but if you click and go to the product page both the slider and latest products then have the red price with line through ?
take a look at my site i am working on at http://www.lincs-golf.co.uk to see what i mean
thanks
RobI am using VM 1.1 and Joomla 1.5
Sherlock FriendSherlock
- 2478 times in 2162 posts
May 30, 2008 at 6:54 am #251146Hi robandyuk !
This is Problem in latest product module . I think you will find it in forum Virtuemart ! http://forum.virtuemart.net/1 user says Thank You to Sherlock for this useful post
robandyuk Friendrobandyuk
- June 2007
May 30, 2008 at 9:50 pm #251283Thanks for the quick reply. I did not think it was a vm fault with it not working in both the ja scroller module as well as the latest product one. But as you said after a search on thier site I have now found a work arround
thanks again
RobSherlock FriendSherlock
May 31, 2008 at 1:32 am #251312Hi robandyuk !
Please post your way to solved it , I think there are many member need it !robandyuk Friendrobandyuk
- June 2007
June 6, 2008 at 7:44 am #252280What i did was publish the all in one module on the front page but un-selected all the options except the latest products. this made all the other modules which showed the prices work ok.
hope this helps
RobNovember 17, 2008 at 3:08 pm #279419I have the same problem but it effects any module showing VM products on homepage.
I have unpublished the JA VM Slider, reset it to latest products only then republished but nothing has changed. I have looked on the VM forum but I cannot find any related articles. can anyone point me to the correct article or suggest a work round.
URL: http://thekaraokeplace.co.uk/karaoke
Joomla 1.5.7, VM 1.1.2, PHP4.2, godaddy hosting
After posting this i managed to get a reply from VM Forum. they gave me a plugin to install which worked first time! If you are using Joomla 1.5 install the following plugin, make sure to publish it.VM mainFrame plugin for Joomla 1.5
Thanks to aravot @ VM 😀
This topic contains 6 replies, has 3 voices, and was last updated by ccli4d 16 years, 1 month ago.
