September 13, 2017 at 10:34 am #1061777
The option "Display in Menu" in the Joomla menu does not work in the T3 Template Menu (megamenu is disabled, i do not need it).
September 14, 2017 at 2:02 am #1061972Hi
May I know the template and T3 version of the site?
So I can replicate it and check.
RegardsSeptember 14, 2017 at 1:25 pm #1062124T3 Bs3 Blank 2.2.7
T3 Framework 2.6.7In MegaMenu works the option,
megamenu is disabled, it does not workPankaj Sharma ModeratorPankaj Sharma
September 14, 2017 at 1:29 pm #1062126Hi
Did you check it with default Joomla template?
Is it working there?Regards
September 19, 2017 at 12:00 pm #1062925I downloaded and installed the current version of t3_blank templates
And its work in the Joomla-Beez3 Template.
September 20, 2017 at 2:52 am #1063012Hi
Thanks for the report, I raised this issue to the development team so it can be fixed in the next update of T3.Regards
Mo0nlight ModeratorMo0nlight
- 99 times in 97 posts
September 21, 2017 at 4:01 am #1063249Hi.
You could try this. Edit the file : /plugins/system/t3/includes/menu/t3bootstrap.tpl.php
Look for:
foreach ($list as &$item) :
Add this under above code
//intergration with new params joomla 3.6.x (menu_show) $menu_show = $item->params->get('menu_show'); if (empty($menu_show) && $menu_show!==null) continue;
Hope it helps.
September 25, 2017 at 1:28 pm #1063956It works. Thank you!
September 26, 2017 at 2:13 am #1064042You are welcome!.
We will fix it the next update of T3.Regards
December 8, 2017 at 12:50 pm #1079914Hi, i’m also having the same issue with the JA University template on T3. Is there a similar fix please, this directory/file doesn’t exist on my server.
December 10, 2017 at 2:26 pm #1080096Hi
The path is for the T3 plugin, Kindly check it in the plugin folder of site and if the issue remains same, please share the T3 version and template version you are using on your site.
I will have a look over it.Regards
This topic contains 10 replies, has 4 voices, and was last updated by Pankaj Sharma 7 years ago.
