Tech-xml Friend
Tech-xml
- October 2010
- 5 times in 2 posts
June 7, 2015 at 10:07 am #207056Published the Module JA Yahoo Weather in position sidebar-1 frontpage (Magazine), however it is not displayed. I also tried with other modules.
pavit Moderatorpavit
June 7, 2015 at 12:38 pm #573177Hi
You need first to create a new JA ACM category listing module , then assign the sidebar-1 position into it
I created one as example for you please check now
Tech-xml FriendTech-xml
- October 2010
June 8, 2015 at 7:49 am #573224@pavit After day working with Teline, I encountered some problems that even following the demo and documentation I can not resolve.
The problems:
1 – The titles of the modules in the Magazine section does not appear
2 – The module – Featured Events not working properly
3 – Modules published on the sidebar-2 are not displayed
4 – In the module More Articles (Magazine) The article title color is incorrectTech-xml FriendTech-xml
- October 2010
June 9, 2015 at 12:37 am #573374@pavit – To better understand the problems I am sending some attachments.
- pavit Moderator
June 9, 2015 at 6:46 am #573404Hi
I opened a support ticket for your issue ( VJO-897-18046 ) Joomlart’s developer will take a look at it , please do not change or disable login credentials .
- October 2010
- October 2010
June 11, 2015 at 11:50 am #573718I have a serious problem on my site that prevents you from continuing my work. Create this post since the day 6. The aid has been slow and have not received responses.
- October 2010
June 11, 2015 at 11:50 am #738732I have a serious problem on my site that prevents you from continuing my work. Create this post since the day 6. The aid has been slow and have not received responses.
- October 2010
June 12, 2015 at 2:13 am #573758Able to identify the most serious problem was a plugin conflict SEF Jreviews. The titles of modules are now normal.
Now I need help to adjust the CSS MORE ARTICLES module and footer social links.
- November 2014
- 3854 times in 3563 posts
June 12, 2015 at 8:49 am #573812
@insofticursos: You can fix the bug above with my solution below+ Create templates/ja_teline_v/css/custom.css file and add new rule
.t3-spotlight .nav > li a i {
margin-right: 10px;
}.magazine-featured.style-4 .magazine-item-main .article-title h3 {
color: #eee ;
AuthorPostsViewing 10 posts - 1 through 10 (of 10 total)This topic contains 10 replies, has 3 voices, and was last updated by Tech-xml 9 years, 6 months ago.
Display problem in Sidebar-1
