  • dasaiz Friend
    #149148
    JA Vauxite does not look good with the written domain www
    The problem is that the web is smaller than in typography or chrome with explorer
    however if www is written without the typeface size is correct
    I suppose it’s a problem of css but not located, any idea?
    Thank you.
    histeriks Friend
    #334535
    dasaiz;167307Hello,
    Thank you.
    Hi dasaiz,
    can you please just tell me, do you have .htaccess file in your site root (not htaccess.txt)?
    Are you using any SEF component, and do you have SEF enabled in your Joomla configuration?
    Also, can we have the link to your website?
    dasaiz Friend
    #334548
    Hello and thanks,
    I activated .htaccess for SEO and now for canonical
    RewriteCond %{HTTP_HOST} ^corredordemontana.com [NC]
    RewriteRule ^(.*)$ http://www.corredordemontana.com/$1 [L,R=301]
    The problem now is with or without www logically to activate canonical
    but before it was only with www
    the url is listed above
    Thanks a lot
    histeriks Friend
    #334687
    dasaiz;167337Hello and thanks,
    Thanks a lot
    Can i have your login info on PM?
    dasaiz Friend
    #334692
    Any idea that could be happening with the template?
    I can supply you the information you requested
    Please tell me things about myself I can test them
    Anything about it will be helpful
This topic contains 5 replies, has 2 voices, and was last updated by  dasaiz 14 years, 9 months ago.
