mengfei Friend
mengfei
- February 2008
November 5, 2008 at 9:17 am #135092Hi Admin,
I feel a bit unbelievable with this problem. Please have a look on attached photo. Viewed under IE6. Why until now still have this problem? I found this problem on my demo site. Then have a look on your demo site as well. Ends up the same display issue. :((
Please advice on what to do with this. This demo set is totally new installation using Quickstart. :(( :((
Koo
jjwijman Friendjjwijman
- January 2006
November 5, 2008 at 9:00 pm #278202mengfei Friendmengfei
- February 2008
November 6, 2008 at 12:30 am #278213Yes, I have read your thread before i post this. This is the menu problem i think. Any helps?
- January 2006
November 6, 2008 at 7:33 am #278244<em>@mengfei 89554 wrote:</em><blockquote>Yes, I have read your thread before i post this. This is the menu problem i think. Any helps?</blockquote>Yes I have had helps (even after a PM in which I sent inlogcodes), but no solution yet.
Sherlock FriendSherlock
- 2478 times in 2162 posts
November 6, 2008 at 8:44 am #278251Hi, if you use Joomla 1.0, you can view this link: http://www.joomlart.com/forums/topic/ja-slideshow-in-ie6/
If you use Joomla 1.5, please edit ja.slideshow.js (modulesmod_jaslideshowja_slideshow folder), search this line:
this.div.setStyles({display: 'block', height: (this.height + 'px'), overflow: 'hidden', position: 'relative', width: (this.width + 'px')});
Change to
this.div.setStyles({display: 'block', height: (this.height + 'px'), overflow: 'hidden', position: 'relative', width: (this.width + 'px'), padding: '0'});
- February 2008
November 6, 2008 at 8:56 am #278254Hi nguoiabcd,
thanks for reply… Tried but still same display problem. And I dont think that is slideshow’s problem. Maybe I am wrong. 😛
Regards;
KooSherlock FriendSherlock
November 6, 2008 at 9:05 am #278257Hi,
Can you please PM me your site admin account as well as FPT account? Without investigating into the codes, I am afraid that we can not provide any solutionmengfei Friendmengfei
- February 2008
November 6, 2008 at 9:14 am #278261Oh, I am setting up on my pc localhost only. It is offline. And I do not changes anything yet from quickstart 1.5 installation.
JA Olivine demo on http://www.joomlart.com/templates_demo.php?template=olivine are totally the same screen of what I see..
I suggest you get a IE 6 and have a look on the demo site actually.
Regards;
November 7, 2008 at 4:58 am #278398I’m sure with you that demo site works fine with IE 6, because have so much users view it by IE 6 .
you can ask jjwijman or read his thread
goyat Friendgoyat
- 3 times in 1 posts
November 8, 2008 at 1:54 pm #278572I have the same problem. I tried everything listed in the forum, but it did not solve the current issue. I am useing Joomla 1.5.7. With FF and IE7, the template works fine. The IE6 is the big problem. I can not open my new site right now. Right now, I disabled Slide module at http://www.joomlajp.org/
- January 2006
November 8, 2008 at 2:46 pm #278575For my site the solution here:http://www.joomlart.com/forums/topic/ja-slideshow-in-ie6/ works fine.
But as you can see there, it causes 2 extra errors displayed by Firebug.
- February 2008
November 10, 2008 at 1:08 am #278657jjwijman, from what I see, your problem is different from what I and another user goyat facing.. It is about the mainmenu that displayed out of order on IE6, not the JA SLIDESHOW.
Hi goyat, mind to tell what IE 6 version no you are testing on? Mine is IE 6.0.3790.183
- February 2008
November 10, 2008 at 2:46 am #278659Ok all, now the problem solve. I feel really sorry for the trouble caused. I am just wasting your time looking at this display issue.
The menu working fine after the JavaScript was enabled; by default I think IE6 disabled the JS. What a shame. Hmm…
Sorry again for inconvenient. 😮
Regards;
November 10, 2008 at 8:37 am #278682OK
I wil mark this topic is solvedAuthorPostsViewing 14 posts - 1 through 14 (of 14 total)This topic contains 14 replies, has 4 voices, and was last updated by Sherlock 16 years, 1 month ago.
Display problem with IE6
