perdu Friend
perdu
- June 2007
- 20 times in 1 posts
July 5, 2007 at 8:57 pm #121267If I set the ja-news module to display on any page other than the frontpage component it doesn’t display correctly see screenshot….
ShannonN FriendShannonN
- July 2006
- 172 times in 49 posts
July 5, 2007 at 9:09 pm #223565perdu;20103If I set the ja-news module to display on any page other than the frontpage component it doesn’t display correctly see screenshot….
Hi Perdu
give us a live url to play with and I’ll have a look its easier to diagnose when you can see the code in action and compare to working sites elsewhere
Thanks ShannonNperdu Friendperdu
- June 2007
July 5, 2007 at 9:17 pm #223567Hi Shannon,
I’m doing it all on xampplite at the moment so nothing live. All I’ve done is basically installed the quick start and then decided to use a static page instead of the frontpage comp. but for some weird reason their seem to be some css problems if it’s placed on any other pages, works perfectly on the frontpage.ShannonN FriendShannonN
- July 2006
July 5, 2007 at 9:23 pm #223568perdu;20110Hi Shannon,
I’m doing it all on xampplite at the moment so nothing live. All I’ve done is basically installed the quick start and then decided to use a static page instead of the frontpage comp. but for some weird reason their seem to be some css problems if it’s placed on any other pages, works perfectly on the frontpage.Check that you are using absolute links and references if you are working locally other than that its just too hard without access to diagnose, I use JSAS which handles local stuff a bit better than xamp, also when you assigned this static frontpage did you turn off the original home/frontpage? Did you assign it in menus etc as a static page? Other than that I can’t think of much that should throw it out
Does Quillaja have a quickstart package, so many of these templates I don’t get time to look at them all 😉AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by ShannonN 17 years, 4 months ago.
Display problem with ja-news when not using frontpage comp
