freissmann Developer
freissmann
- February 2011
- 29 times in 1 posts
March 13, 2012 at 1:29 pm #174942Hi,
we are trying to use JA Tabs with ORES template and everything looks good so far.
We have a small display error with the text – on the right side some letters are simply “cut” (see attachment).
Until now we did not find a solution for that (even with fixing the width of the tabs…).If we change the zoom ratio + or – and then go back to 100% everything is fine and letters are not cut anymore.
This error appears on IE, FF and Chrome.
Direktlink to error site can be found here.
Does anyone has an idea on how to solve that small issue?
Greetings Frank
TomC ModeratorTomC
- October 2014
- 3155 times in 2495 posts
March 13, 2012 at 3:59 pm #443451Greetings Frank:
So that I may try to best assist you, please provide the url of the site you’re working on,
as well as set “Optimize CSS” to “No” within your Template Manager–General Settingsfreissmann Developerfreissmann
- February 2011
March 26, 2012 at 12:18 pm #445682Hi Tom,
just sent you an PM – please confirm if you have recieved it.
Frankfreissmann Developerfreissmann
- February 2011
March 26, 2012 at 5:23 pm #445736Hi Tom,
thanks for your help so far – we could fix the issue by adjusting the padding of .ja-tabswrap div.ja-tab-subcontent…NOW we have another issue – we use the show “introtext” and get the “read more” link shown at frontend but facing two problems:
1. We cannot click the “read more” button.
2. We cannot change the “read more” text (localisation)Any ideas?
By the way Dev-URL is now without login:
http://absc.rrc-group.deGreetings
FrankAuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by freissmann 12 years, 9 months ago.
Display problem with JA Tabs
