  • h2onewmedia Friend
    #133126
    Hello.
    Is it possible to display the Tabs in the main body section of my page instead of a module position? If so, how would i do this?
    Thank you.
    damian Friend
    #269645
    Yes you can use ja tabs in content. Use ja tabs Plugin.
    h2onewmedia Friend
    #269646
    thanks for the reply Damian
    I am still relatively new to this, so how would i set the plugin to display on the page that i want it?
    damian Friend
    #269951
    Publish your ja tab plugin and type
    {jatabs type=”content” position=”top” width=”100%” height=”100%” mousetype=”click” animType=”animMoveVir” skipAnim=”false” duration=1000 }
    Your content goes here
    {/jatabs}
    markwhi Friend
    #271067
    <em>@damian 79130 wrote:</em><blockquote>Publish your ja tab plugin and type
    {/jatabs}</blockquote>
    This works nicely however the drop cap formatting needs to be removed from the content as it interferes, how is the done on a page by page basis?
This topic contains 5 replies, has 3 voices, and was last updated by  markwhi 16 years, 2 months ago.
