  • timtecsa Friend
    #695175
    @jooservices
    I have built most of the site ( http://j344tag.gpmnews.com/ ) as you suggested without using quickstart. A couple of small problems which I haven’t managed to resolve.
    1. The megamenus (mega-left) on main menu items ‘CONG B’ and ‘CULTURE’ have category title blocks not top aligned with titles in mega-right. How to fix?
    2. I created a jacm module, [Magazine – Home] Category Listing 1 – arts et culture to sit between the Video and Events modules on the homepage but it doesn’t seem happy. How to fix? Enable it and you will see the effect.
    Tim
    Hi Tim,
    Is this your site? please ask the owner of site to send us screenshot of how he wants it should be, I’m happy to help.
    Hi Tim,
    timtecsa Friend
    #697295
    Hi @Saguaros
    It is a @victortopper site but I am helping him to build it and transfer content from mwind.org which I volunteered to help him build some time ago. We share French language, of sorts 🙂
    A previous test build from quickstart can be seen here where the ARTS ET CULTURE module seems happy. mt5.mwinda.org
    Tim
    c.c. @victortopper
    timtecsa Friend
    #750927
    Hi @Saguaros
    Tim
    c.c. @victortopper
    victortopper Friend
    #697298
    Hi M.Saguaros,
    Sir Tim is my friend, the
    He helps me a lot on the construction site because it has an experience of over 10 years on joomla templates and joomlArt.Il has the access code on the server and it is the only one to possess the codes.
    So I can confirm that he can use these codes to help me solve some problem of my sites.
    I am at your disposal for further information
    Best regards
    victortopper Friend
    #750930
    Hi M.Saguaros,
    Best regards
    Please create your own thread and add login info (so that only staff can see that info) and clarify the issue and we can help you out.
    victortopper Friend
    #751038
    Mon ami @timtecsa a construit le site ( http://j344tag.gpmnews.com/ ) sans quickstart comme @jooservices m’a sugger? . Les titres des modules dans megamenu sont pas align?s. Comment les r?pairer?
This topic contains 10 replies, has 3 voices, and was last updated by  victortopper 9 years, 1 month ago.
