  • sunit Friend
    #184468
    I did not find the answer hence questioning. Do I need to eneable both cache: default joomla cache and T3 frame work cache? or simply enabling T3 framework cache will work. Right now, I have default joomla cache mode is off and all cache is handled by T3 framework. I am using “Blank & Clean JA T3 V2 Framework Template”.
    Regards,
    Sunit
    Hi Sunit,
    You can use JAT3 cache only, using both of them is unnecessary
    sunit Friend
    #481865
    Thanks Saguaros!
This topic contains 3 replies, has 2 voices, and was last updated by  sunit 11 years, 11 months ago.
