Viewing 2 posts - 16 through 17 (of 17 total)
  • careermind Friend
    #490051
    <em>@pavit 369170 wrote:</em><blockquote>Hi careermind
    The Typography menu item is pointing to an article called Typography where is showed all the typo you can use in your articles.
    That’s are menu and are there because they belong to the joomla core if you don’t need them simply remove
    The menu you need for your Ja_Social template is the Main Menu</blockquote>
    Thank you Pavit! In the event I want to remove Social Template to get the “Naked” Joomla 2.5, what should I do? I guess I play around with the core first…
    <blockquote>Thank you Pavit! In the event I want to remove Social Template to get the “Naked” Joomla 2.5, what should I do? I guess I play around with the core first…</blockquote>
    Goto your Extensions – Template Manager page – you will see a list of all templates installed simply set as default the Beez5 template clicking on the star grey icon on the right default column.
This topic contains 17 replies, has 2 voices, and was last updated by  pavit 11 years, 7 months ago.
