  • hoknight Friend
    #994096
    Can you have a look why the module does not show on position "photographer-mast-top"?
    Module ID: 199
    The module has assigned on homepage.
    If you inspect element with Firebug in Firefox, you will see that the module is rendered there but it can’t display due to the conflict in JS and style with 3rd party extensions on your site: jux_content slide, etc…
    You can try to disable them first.
This topic contains 1 reply, has 2 voices, and was last updated by  Saguaros 7 years, 11 months ago.
