  • frankgabriels_1961 Friend
    #1091706
    For our website we’re considering to buy the JextBOX plugin "login to read more".
    Detailed information on this plugin can be found here:
    http://jextbox.com/jextbox-login-to-read-more/documentation.html
    I’ve looked at different options and solutions for the use of a "read more" system.
    Our organisation has members (they can read everything, after logging in) and public visitors (they are generally blocked from the full content, but we sometimes allow them full acces to the article).
    The plugin only costs 15$, but it’s a bit foolish to spend money (even if it’s only 15$) on something that"ll never work…
    If I’m not mistaken, all articles in Teline are loaded to the browser by means of the ACM’s.
    I’ve read somewhere that, in order make "read more" options work, the id of the article must be passed on and often modules or plugins don’t pass this crucial id number
    I’m not that much of a tech specialist so my question is:
    does Teline V (with the ACM) work with JextBOx "login to read more" plugin?
    Thanks for your technical advice
    Greetz,
    Werner
    Pankaj Sharma Moderator
    #1091962
    JA ACM is a custom module that loads the articles. When the article is opened its like a normal article of Joomla.
    I can not assure about the plugin you want to buy as it depends on the plugin is it support the ACM or not.
    I never tried this plugin and not sure about its working with ACM as its custom module. You may ask the plugin provider to check its support for 3rd party templates and modules.
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 6 years, 10 months ago.
