  • wolfix Friend
    #194605
    I have to double-tap links in the main nav when using iPhone or iPad.
    Thanks!
    Ninja Lead Moderator
    #522035
    I found the problem on your site from the custom.css file, you have fixed the width on menu site 740px. You can see it in red below:
    Open templates/ja_obelisk_grayish_copy/css/custom.css file:
    .container, .navbar-static-top .container, .navbar-fixed-top .container, .navbar-fixed-bottom .container {
    width: 640px !important;
    .t3-mainbody {
    max-width: 740px !important;
    .row-fluid .span12,
    .span12 {
    max-width: 700px !important;
    /* end joomlart cod */
    .t3-mainbody {
    padding-bottom: 40px;
    padding-top: 20px;
    margin: 10px 0 10px 10px;
    .t3-mainbody .container{
    wolfix Friend
    #522066
    I commented-out all the code with the fixed width… but I still have to double-tap the links on the main nav bar to go to a new page.
    Must be something else….
    wolfix Friend
    #522106
    I just realized I only have to double-tap links on iPhone or iPad if I am logged in as a user. If I logout, I don’t have to double tap.
    #522138
    I have checked your site on iPad device but I could not see the problem now. If possible, include a screenshot and explain in more details. Also, let me know how to reproduce the issue, I will try to debug and help you out.
This topic contains 5 replies, has 2 voices, and was last updated by  Ninja Lead 10 years, 9 months ago.
