  • proven Friend
    #143607
    Hi there
    There has been problem with Opal Template, the submenus in the mainmenu are only half visible,
    there were posts which were already posted long back and were still unanswered……….below is the post unanswered
    http://www.joomlart.com/forums/topic/dropdown-proeblems-ie6/
    Thanks in advance ….
    1. Snap2
    mihirc Friend
    #314975
    <em>@proven 141554 wrote:</em><blockquote>Hi there
    Thanks in advance ….</blockquote>
    Hello proven,
    I had also put an request for a link in the earlier message that you linked to, putting a request now as well.
    What happens is that unless we see the problem we cannot give you the right solution, as we have to keep on guess. The first guess of mine didnt work!
    To get support, you can also submit a ticket from your member section.
    Regards,
    Mihir Chhatre.
    Anonymous Moderator
    #315959
This topic contains 3 replies, has 3 voices, and was last updated by Anonymous 15 years, 3 months ago.
