Viewing 15 posts - 1 through 15 (of 21 total)
  • dieudonne Friend
    #195939
    we are trying to use JA Social Feed Plugin with JA Teline IV in Joomla 2.5, but we have 2 problems.
    1 : the pictures are duplicated and the pictures are too big.
    In the parameter we put 180/180px for minimum Image Width / Height…
    2 : the characteris always put like
    See our 2 screenshots for more understanding.
    So what can we do to fix this 2 problems ?
    Thank.
    1. 2014-03-19_16h07_48
    2. 2014-03-19_16h20_46
    Are you using the latest version of this plugin?
    And please also check settings for category or menu item of page where article is displaying, it may inherit the settings for images from there.
    dieudonne Friend
    #527450
    thank for the answer.
    Yes we use last version of this plugin (1.1.4).
    And I don’t understand for the menu settings… there is no option about pictures…!
    And for the character ‘ ?
    Regard.
    Did you try the solution in this thread? http://www.joomlart.com/forums/topic/duplicated-pictures-how-to-fix/#post-509682
    For the character ‘, could you post URL of page where I can see this character here?
    dieudonne Friend
    #527674
    thank for your answer.
    For the pictures, it is ok, I aleady ask for this problem (bug ?) and I don’t remember it.
    For the accent, here is the link :
    http://www.cire.be/sensibilisation/facebook
    Maybe you’ll find something…
    Regard.
    dieudonne Friend
    #527858
    Anynews for the accent problem ?
    Regard.
    Could you PM me admin account of site you’re working on? I will try to check what’s wrong here.
    dieudonne Friend
    #531935
    sorry for the delay.
    I just sent you PM.
    Regard.
    You can try opening file: plugins/system/jasocial_feed/jasocial_feed.php
    Look for function cutTitleFromContent , you will see this line of code inside this function
    [PHP]
    $content = strip_tags($content);
    [/PHP]
    replace it with:
    [PHP]
    $content = htmlspecialchars_decode($content);
    [/PHP]
    dieudonne Friend
    #532052
    thank, but sorry it doesn’t work. But maybe it’ll work with new content ?…
    Regards.
    You are right.
    After changing code above, you should run the cron job to import feed again. It should work 🙂
    dieudonne Friend
    #532062
    Nope, it doesn’t work. Still have these &#039 with new facebook post….!
    If you have a other idea ?
    Regard.
    1. 2014-04-23_14h18_30
    It’s weird, could you PM me ftp account of your site? I will investigate it further.
    dieudonne Friend
    #532242
    I just sent you a PM with ftp access.
    Regard.
    Hi diedonne,
    Try to change my suggestion above:
    [PHP]
    [/PHP]
    to
    [PHP]
    $content = html_entity_decode( $content, ENT_QUOTES, “utf-8” );
    [/PHP]
    also make sure that you disable cache plugin, remove old feed imported in your site and run the cron job again.
This topic contains 21 replies, has 3 voices, and was last updated by  Mark Kennedy 10 years, 6 months ago.
