  • gedasbn25 Friend
    #950835
    Hi, Superior Template! But I am missing EB documentation, can you please provide the steps how to set up EB page as on your demo page?
    Best,
    Gedas
    I’ll forward your request to the joomlart support to integrate documentation with easyblog section, in the meanwhile you can download and install the easyblog theme from download page and set the Blog menu item to use the wall layout.
    1. Screenshot-at-lug-17-22-30-29
    gedasbn25 Friend
    #950848
    Hi @pavit,
    So I did what you said, but now which module position I should use for the sidebar? The wall layout shows only 2 columns ( Blog menu item is set to Grid Number 3), how to make it show 3 columns?
    1. screenshot-yuppieonline-com-2016-07-17-15-47-22
    Hi there
    I’m sorry my fault, i gaved a wrong layout name, use the Default layout and publish easyblog modules in sidebar-2 position.
    gedasbn25 Friend
    #950860
    Okay, now it works, thanks again!
    iaassens Friend
    #951189
    Hello, trying to install the Joomlart easyblog theme gives this error:
    There was an error installing the theme as the same folder exists in the themes folder.
    Did you verified if it is already installed ?
    iaassens Friend
    #951396
    Hi pavit,
    I did not install the quickstart so I assume not. What is the theme called when installed?
    iaassens Friend
    #951479
    Unzipped everything and uploaded the theme manually, now it works.
This topic contains 8 replies, has 3 voices, and was last updated by  iaassens 8 years, 4 months ago.
