  • timheel Friend
    #191836
    I’ve changed a setting, which I can’t remember, which is now preventing EasyBlog appearing when I click on the menu link – I just get a blank screen. Also, in the EasyBlog dashboard when I go to categories and click on a category to edit it I get a blank screen. Similarly, when I click on an individual blog posting to edit it I also get a blank screen.
    If you could help pinpoint the issue I’d much appreciate it.
    Thanks Tim the-heeleys.co.uk
    Hello Tim,
    I accessed backend of your site > Global configuration > and enable Error Repoting. Then this error shows in frontend:
    Fatal error: Allowed memory size of 25165824 bytes exhausted (tried to allocate 120 bytes)
    Seems to be you’re running out of the allowed memory size.
    If you have access to your php.ini you should look for a line that contains memory_limit and set its value to a greater value which works for you)
    In case you can’t access the php.ini try setting it trough the .htaccess file:
    php_value memory_limit 1000M
    If that also fails you should contact your hosting provider. Some have a web interface to allow changing this settings. Unfortunately others doesn’t allow changing it at all, you need to ask them for help.
    timheel Friend
    #510766
    Hi Saguaros,
    Many thanks for taking a look. I changed the files – but to no avail. I ended up going into my hosting interface and making the changes there. And everything is now working. Which means I’ve got a bit of work to do perfecting everything.
    Your help and time is much appreciated. Regards Tim:)
    You’re almost welcome, Tim
This topic contains 4 replies, has 2 voices, and was last updated by  Saguaros 11 years, 1 month ago.
