korpisa2 Friend
korpisa2
- January 2008
- 2 times in 2 posts
September 18, 2016 at 1:50 am #968884Dears, I´m wondering if there is a known issues with JA_RESUME and easyblog component? I have followed the steps in the documentation (https://www.joomlart.com/documentation/joomla-templates/ja-resume#easyblogs) but I don´t see any content on the page.
I´m running locally.
Saguaros ModeratorSaguaros
September 20, 2016 at 2:54 am #969296Hi
It should work fine with template, see Demo: http://ja-resume.demo.joomlart.com/index.php/en/component/easyblog/?theme=ja_resume&Itemid=189
You can put your site online and send us the login info so we will help you to check what’s wrong here.
korpisa2 Friendkorpisa2
- January 2008
September 20, 2016 at 8:08 pm #969555Hi, when I try the demo site from the link you provided none of the menu items on the main menu work, except More which expands the side panel.
For example open
and then
http://ja-resume.demo.joomlart.com/index.php/en/component/easyblog/#about_me
-> How is navigation between the blog and the rest of the site supposed to work?
For me it doesn´t open anything, URL changes but nothing happens on chrome.
What I´m trying to achieve is a menu item on the main menu of ja_resume template which opens the easyblog in wall mode with main menu from the template still visible The only way I manage to see the test post I have created is to assign some other theme than ja_resume for the menu item. -> It jumps to default easyblog page.
I´ll try to put the site online tomorrow but would appreciate if you could try to reproduce the issue.
September 21, 2016 at 1:39 pm #969846Let me know when your site is online, I will check with the team for the demo site to see what’s wrong
- January 2008
September 22, 2016 at 7:22 pm #970294This reply has been marked as private.Saguaros ModeratorSaguaros
September 23, 2016 at 2:39 am #970358Try to take a backup for the header block file and apply suggestion here: https://www.joomlart.com/forums/topic/top-navigation-menu-problem-in-1-0-2-version/#post-970173
- January 2008
September 27, 2016 at 9:45 pm #971516Hi, main menu now works on your demo pages except that after navigating to easyblog clicking of home menu item does nothing..
And on my test site I still get an empty page when clicking a menu item which I have created following the instruction.
I also tried to create a menu item which displays latest post. Also for this menu item the only way to display the post is to assign the build-in templete (not ja_resume) to menu-item.
Many thanks.
Could you also update the link for post settings in the easyblog configuration chapter 3.1
It is currently showing detail settings..
https://static.joomlart.com/images/userguide/ja_templates/ja-resume/easyblog-category-setting.jpg
September 28, 2016 at 1:59 am #971530I checked the STORIES menu item on your site and it was assigned with default template style which used ‘photography-features-intro’ layout that doesn’t include component block so you don’t see any content there.
I just duplicate the default template style to have a new style call ‘JA Resume – Default(2)’ and change the layout to use ‘default’ layout (you can see in Layout tab) and it displays fine now.
Also, from this STORIES page, I can navigate to other menu items in the main menu, it’s working now, right?
- January 2008
September 28, 2016 at 9:20 pm #971881Thanks. It works. How to change the background of the main menu/header bar so that it would be same in onepage and easyblog views?
September 29, 2016 at 3:36 am #971972Style for the header will require a bit much of code here.
You can change the theme for the new style created above via template manager section.
- January 2008
September 29, 2016 at 9:44 pm #972286Ok. Managed to do that on my local version.
Any tips how to fix the height of the "header" so that it would not change when scrolling down. I don´t need a logo so a shrink-version of the header is enough.
This topic contains 11 replies, has 2 voices, and was last updated by Saguaros 8 years, 3 months ago.
