  • SWORDBROS. Friend
    #852369
    My web site is
    http://www.poliskoleji71.com I read all your documentations
    https://www.joomlart.com/documentation/joomla-templates/ja-social-ii
    I have done all but still not as yours demo site.
    Especially login and log out problem.
    Thanks in advance
    Best regards
    Pankaj Sharma Moderator
    #862015
    You login page look like as in demo site .
    could u provide a screenshot for the second issue and add your site admin details to check the login /logout issue .
    Kindly attach a screenshot and illustrate details of login/logout issue . It will help me to check the problem on your site .
    SWORDBROS. Friend
    #864435
    #864994
    I did not found the super user admin details of your site to check the login logout problem in your last post .
    Kindly provide me the info so i can perform the above steps.
    SWORDBROS. Friend
    #886128
    #886152
    I logged in from the link u provided in Step 2. Then logout .
    Because i already logged out from the with step 2 . i can not logged out again on site .
    Kindly check it again given details of the error your are getting with description and screenshot of error .
    I also tested demo site did not notice any problem in login and logout on site .
    For the login/logout redirection kindly checkout the component documentation or on its support forum Here .
    SWORDBROS. Friend
    #886295
    Dear Pankaj Sharma
    Could you setup all web site as your demo web site? With EasySocial?
    #886329
    Its a personal to setup site and does not cover support scope ,You need to follow the documentation and install the extension on quickstart package to make site like in demo . Or u can use JA Quickstart installation services to install site like demo site .
    SWORDBROS. Friend
    #886370
    845564 JATC Standard Membership Jan 12, 2016 Completed $89.00 ?
    SWORDBROS. Friend
    #886374
    SWORDBROS. Friend
    #886403
    #886474
    here are the screenshot of settings on
    Module position : content-mass-top
    Module class suffix : section-sign
    Settings : http://prntscr.com/a54cde
    Also Please navigate to admin >>> Extensions >>> Template Manager >>> choose default template >>> Add-ons >>> Template Extended styles >>> make sure to load predefined style for Easysocial in appropriate pages, if you’re not sure how to set it, just choose All pages
This topic contains 11 replies, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 10 months ago.
