August 30, 2017 at 1:39 am #1059306Hi,
Could you update the credentials of your site so I can check for you?
pictureworker Friendpictureworker
- August 2015
August 30, 2017 at 5:33 pm #1059507This reply has been marked as private.pictureworker Friendpictureworker
- August 2015
August 30, 2017 at 8:15 pm #1059517This reply has been marked as private.Saguaros ModeratorSaguaros
August 31, 2017 at 2:38 am #1059562Hi,
Yes, your reply are private, could you share the URL also?
- August 2015
August 31, 2017 at 7:04 am #1059609This reply has been marked as private.Saguaros ModeratorSaguaros
September 4, 2017 at 6:29 am #1060155Hi,
This is weird issue, do you have any customization on the template?
Could you also share ftp account of your site?
- August 2015
September 4, 2017 at 7:41 am #1060165This reply has been marked as private.Saguaros ModeratorSaguaros
September 5, 2017 at 3:11 pm #1060500Thanks for the info, let me check and will get back to you.
- August 2015
September 7, 2017 at 2:52 pm #1061014This reply has been marked as private.Saguaros ModeratorSaguaros
September 12, 2017 at 1:15 am #1061528This is weird issue, give me more time to investigate deeper in this.
- August 2015
September 12, 2017 at 3:11 pm #1061648Ok, finally i install a backup version on local server…updated step by step, joomla, modules, languages, components and finally JA Nuevo 1.05.
Then moved the local version to main server with Akeeba Kickstart.Thanks for your helps
This topic contains 11 replies, has 2 voices, and was last updated by pictureworker 7 years, 2 months ago.
The topic ‘english and italian navigation not loaded on mainnav’ is closed to new replies.
