I can also confirm that the commenting out of the 3 lines works. Thanks all.
<em>@ebajh69 103024 wrote:</em><blockquote>Commenting out Lines 282-284 as suggested by phghgjh works.
This will turn off the AUTO Drop Cap from every article. If you want to add it to an individual article, you still can by using <span class=”dropcap”>X</span>.
Thanks</blockquote>
Thanks Guys, this was exactly the help I needed.
Cheers,
Abdujap
OK – so I am trying to add this functionality into the latest 1.4 JA Zibal – where do I add this CSS Code?
I am doing an upgrade from a Joomla 1.012 site that is using this template along with those bonus types but with the new version 1.4 they are not installed so they do not show up in the migrated content.
I know the issue is solved for now, but I wanted to point out a good solution to this problem that has been in the stickies for JA Pyrite for quite some time now:
http://www.joomlart.com/forums/showpost.php?p=116489&postcount=5
This topic contains 19 replies, has 12 voices, and was last updated by ftht1 14 years, 9 months ago.
