  • tom_laan84 Friend
    #1012542
    I have implemented Xlayout services in ja platon and it works except for it calculates the heights wrong. It gives these big white spaces because it calculates the height as 616px but the actual heighest item is only around 440px.
    What is going wrong?
    May I know which page the issue can be seen?
    tom_laan84 Friend
    #1012792
    You can set min-height value for each item there:
    • Go to file: ROOT/templates/your_default_template/css/custom.css
    • Add this css rule:
      .blog-service .items-row .col.col-xs-12.col-sm-6.col-md-4.col-lg-4 {
      min-height: 460px !important;
    tom_laan84 Friend
    #1012796
    Hi Saguaros, i don’t work with custom.css i use the local less override system but i don’t see how this is a fix for the issue. It still does not fix what is causing the mis-calculation if i’m correct? Ony my other websites where i use these xlayout services the problem is not there and i don’t see any min-height important css there. Shouldn’t we investigate to find the source of the problem instead of putting a bandaid on it?
    Tom
    Hi Tom,
    You will need to work on JS also to control that height in your custom layout.
    If you don’t want to use css, you can inspect the element and add the style as my suggestion above.
This topic contains 5 replies, has 2 voices, and was last updated by  Saguaros 7 years, 9 months ago.
