  • marielathey Friend
    #137820
    I was away for the weekend and now my site has an error code for line 16, character 1913, ‘J parent node is null or not an object’. I see that this has happened with other templates from Joomlart. Please help as I was very happy with this template and I really dont want to start over!!:confused:
    mihirc Friend
    #289717
    Please answer a few questions mentioned below:
    1. Are you using any pugins? which use JS?
    2. Are you using an swf file or a script called swfobject?
    Regards,
    Mihir C.
    marielathey Friend
    #290037
    Yes, I am using JA Flowlist module on the home page- which is the one with the error
    isgroup Friend
    #290085
    Exactly!
    JA FLOWLIST always comes up with new errors lol :p
    Check the site on IE also. You will surely get a OPERATION ABORTED error :d
This topic contains 4 replies, has 3 voices, and was last updated by  isgroup 15 years, 11 months ago.
