Viewing 15 posts - 1 through 15 (of 17 total)
  • pa1hr Friend
    #133814
    Hello members,
    I use Joomla 1.5.7 with the JA Teline II template.
    When I insert an image into the article and I active the modules JA News 1.3.1, JA News Frontpage and/or the spotlight module I get this error message on the frontend:
    Warning: mkdir() [function.mkdir]: Permission denied in /home/remeeuse/public_html/joomla2/modules/mod_janews/helper.php on line 107
    and:
    Warning: mkdir() [function.mkdir]: Permission denied in /home/remeeuse/public_html/joomla2/modules/mod_ja_catslwi/helper.php on line 95
    I have tried three different installations of Joomla 1.5.7 with the JA Teline II template, and this error message returns all the time.
    Without an image I do not get this error messages.
    With the JA Purity template I do not get this error messages.
    When I activated the sql database I gave myself all the rights.
    Thanks and regards, Hans.
    #273230
    HI pa1hr !
    Please change permission of images folder and sub folder in it to “755” or “777”. this is a problem in permission of folder.
    pa1hr Friend
    #273242
    Thanks for this information!
    Regards, Hans.
    lumawmaung Friend
    #273880
    <em>@pa1hr 83190 wrote:</em><blockquote>Thanks for this information!
    Regards, Hans.</blockquote>
    I also got this error messages. Can you please write in detail.
    I’m beginner of joomla and JA Teline II.
    Thankfully,
    Lumawmaung
    lumawmaung Friend
    #273881
    <em>@hainn84 83178 wrote:</em><blockquote>HI pa1hr !
    Please change permission of images folder and sub folder in it to “755” or “777”. this is a problem in permission of folder.</blockquote>
    Thankfully,
    Lumawmaung
    lumawmaung Friend
    #273882
    I have also face this problem. plz tell me how to change the folders permission.
    #273927
    Hi lumawmaung !
    You go to cpanel >> file manager >> select images folder and change permission for it .
    lumawmaung Friend
    #273951
    <em>@hainn84 84055 wrote:</em><blockquote>Hi lumawmaung !
    You go to cpanel >> file manager >> select images folder and change permission for it .</blockquote>
    Dear hainn84,
    Thank you for your reply. But I don’t use cpanel.
    I use eXtplorer for file management.
    How can I do?
    Thankfully,
    lumawmaung
    lumawmaung Friend
    #274127
    Hi All,
    Please anyone help me for following error code. :confused:
    hainn84,
    I have change folder permission but it doesn’t work corretly.
    It’s shown like the following error codes on the frontpage.
    our URL: click here
    Warning: getimagesize(/home/content/y/o/m/yoma3/html/joomla4p3opl3/images/news/uwintin.gif): failed to open stream: No such file or directory in /home/content/y/o/m/yoma3/html/joomla4p3opl3/modules/mod_janews/helper.php on line 74
    Warning: Division by zero in /home/content/y/o/m/yoma3/html/joomla4p3opl3/modules/mod_janews/helper.php on line 84
    Warning: Division by zero in /home/content/y/o/m/yoma3/html/joomla4p3opl3/modules/mod_janews/helper.php on line 85
    Warning: imagecreatefromgif(/home/content/y/o/m/yoma3/html/joomla4p3opl3/images/news/uwintin.gif): failed to open stream: No such file or directory in /home/content/y/o/m/yoma3/html/joomla4p3opl3/modules/mod_janews/helper.php on line 122
    Warning: imagecreatetruecolor(): Invalid image dimensions in /home/content/y/o/m/yoma3/html/joomla4p3opl3/modules/mod_janews/helper.php on line 126
    Warning: imageantialias(): supplied argument is not a valid Image resource in /home/content/y/o/m/yoma3/html/joomla4p3opl3/modules/mod_janews/helper.php on line 128
    Warning: imagecopyresampled(): supplied argument is not a valid Image resource in /home/content/y/o/m/yoma3/html/joomla4p3opl3/modules/mod_janews/helper.php on line 129
    Warning: imagejpeg(): supplied argument is not a valid Image resource in /home/content/y/o/m/yoma3/html/joomla4p3opl3/modules/mod_janews/helper.php on line 130
    #274152
    Hi lumawmaung !
    You can use eXtplorer for change permission of the images folder, please go to file manager and change prmission of images folder.
    lumawmaung Friend
    #274534
    Hi hainn84,
    I have already changed folder permission. But it doesn’t fix the problem.
    How can I try another way? Please advise me.
    lumawmaung
    #274539
    Hi lumawmaung
    Can you send your URL
    lumawmaung Friend
    #274569
    http://www.yoma3.org/joomla4p3opl3/
    we get warning message and layout problem under IE6.
    lumawmaung Friend
    #274734
    hi nguoiabcd,
    Please tell me what I have to do.
    I have no idea to fix this problem.
    Thank
    #274980
    please edit helper.php
    1.Search line:
    $ext = strtolower(substr(strrchr($image, '.'), 1));
    Change to
    $ext = (substr(strrchr($image, '.'), 1));
    2.search line:
    $rzname = strtolower(substr($image, 0, strpos($image,'.')))."_{$tn_width}_{$tn_height}.{$ext}";
    change to
    $rzname =(substr($image, 0, strpos($image,'.')))."_{$tn_width}_{$tn_height}.{$ext}";
This topic contains 17 replies, has 3 voices, and was last updated by  pa1hr 16 years ago.
