Viewing 15 posts - 1 through 15 (of 29 total)
  • victortopper Friend
    #206654
    I have the same problem like the one I had with the video there is the “Events” module not working.
    In case the module is displayed is what can scroll through the images in the same fa?con that featured items if so how
    thank you
    1. events
    Please verify which version of template you have installed if it is ver.1.0.3 then update it to 1.0.4 , problem is the position settings missing into the menu item for events layout
    victortopper Friend
    #571867
    please you can have the link to download the new version of the template ver 1.0.3 vers1.0.4
    victortopper Friend
    #736912
    <em>@victortopper 475119 wrote:</em><blockquote>please you can have the link to download the new version of the template ver 1.0.3 vers1.0.4</blockquote>
    You can use Joomla Extension Manager component to update Joomlart extensions and templates , just fill in your Joomlart account and click on update
    Take a look HERE
    Take a look HERE
    victortopper Friend
    #571880
    I looked carefully I have the correct version of the template ver 1.0.4 may be you want me to reinstall it?
    victortopper Friend
    #736925
    <em>@victortopper 475134 wrote:</em><blockquote>I looked carefully I have the correct version of the template ver 1.0.4 may be you want me to reinstall it?</blockquote>
    You can send me a super user account to your backend and i will take a look at it , i think it is better than install it again
    Please check now your events page , your 2 modules
    [Magazine – Events] Category Events Listing
    [Magazine – Events] – Featured Events
    Where not assigned to the events page
    victortopper Friend
    #571910
    please me you could make images to see my mistakes
    my last question can rotate the image right to left
    victortopper Friend
    #736955
This topic contains 29 replies, has 2 voices, and was last updated by  victortopper 9 years, 6 months ago.
