  • annaverde Friend
    #142274
    some one can advise a a component compatible with jateline II?
    i tried maXcomment but that’s orrible!
    Anonymous Moderator
    #309411
    Hi annaverde
    Our template is often working fine with all other extensions.
    If you have a problem with maXcomment extension, please let me know your issue.
    annaverde Friend
    #309463
    hi,
    the problem is that the modules ja news & ja news front page dosen’t work if you install maXcomment
    in the attached “layout without maxomment” you can see the site without maxcomment
    in the attached “with…..” you can see the site after the installation….
    1. layoutwithmaxcomment
    2. layoutwithoutmaxomment
    ccvpguy Friend
    #309548
    I use jomcomment from http://www.azrul.com/
    Anonymous Moderator
    #309635
    Hi annaverde
    Your images which you sent are very small. I could not see what is your issue?
This topic contains 5 replies, has 3 voices, and was last updated by Anonymous 15 years, 5 months ago.
