  • albatrozdigital Friend
    #1069810
    Hi!
    I have a problem using Uber template with Fabrik.
    If i have Fabrik enabled the articles titles don’t show.
    After disabling Fabrik the articles titles show again.
    Is there any incompatibility?
    PS: at this time plugins fabrik-framework and fabrik-content are disabled to have the titles working so i can work at the personalization of the site.
    Pankaj Sharma Moderator
    #1069958
    KIndly edit your first post and submit your site details for staff.
    Also, let me know which article is not showing the title
    #1070018
    First post edited.
    #1070107
    I can see the article title is showing on your site
    http://prntscr.com/h237gw
    Kindly check it again or share the URL where i can check this issue.
    #1070251
    Hi!
    I have enabled Fabrik so you can check it.
    Please see this page: http://www.palmeladesporto.pt/pd000/noticias
    #1070257
    Kindly share a temp super user details of site in Private reply.
    #1070279
    #1070286
    I just see that with the article opened the Full Image don’t show either.
    #1070408
    #1070497
    Here it is the package from Fabrik
    https://we.tl/BHGMIUMg9D
    #1070499
    This behavior was happening with fabrik 3.7 and i updated to 3.8 and still the same.
    #1070591
    Hi!
    I just want to give you some feedback, because the problem was from Fabrik and they solved it.
    Here is the Link from the Forum with the explanation, so anyone with the same problem can see it.
    [http://fabrikar.com/forums/index.php?threads/fabrik-3-8-download-not-working.47728/]
    Thank you for your time.
    #1070761
    HI
    Glad the hear the issue is fixed by them.
    It looks like the extension setting overriding the codes and removes the title code that is used by the template in its override.
This topic contains 12 replies, has 2 voices, and was last updated by  Pankaj Sharma 7 years, 1 month ago.
