May 24, 2012 at 6:00 pm #177508
I have successfully installed JA Wall however I am having two problems:
1. I need to remove the facebook commenting widget and cannot locate it anywhere, can anyone kindly assist,
2. I am using the Color Block Light theme, however all the boxes are the same plain color, how do I make that change?
Thank you.
vineyardseashell Friendvineyardseashell
- March 2011
- 19 times in 1 posts
May 24, 2012 at 8:23 pm #454769Hi Ninjapig2000,
To turn off the facebook comments, see the post here.
To turn on the various colours (extended classes), for the contents-head into your article manager, select an article; under the metadata parameters you see an ‘extended classes’ option box; just add the classes there.
The only class options I remember off the top of my head are:
grid-double
grid-triple
item-hotDo a search in this forum or look at the documentation in the JA Wall demo, the rest of the codes can be found there.
Hope this helps you.
Vineyardseashell
1 user says Thank You to vineyardseashell for this useful post
May 25, 2012 at 3:06 am #454819Perfect, just what I needed, thank alot, well appreciated.
napatjo Friendnapatjo
- December 2009
- 2 times in 1 posts
May 25, 2012 at 10:16 am #454876I dont have the Extended classes there in my site, because I didnt use the quickstart, what do I need to install to have the Extended classes field showing? :((
cssyeah Moderatorcssyeah
- June 2006
- 121 times in 81 posts
May 26, 2012 at 3:05 am #454950Hi napatjo,
You click to the item you want to add suffix. Look the right side and open the “Metadata Options” tab. You type some item class suffix to the “Extended Classes” input box.
Ex:
grid-double
grid-triple
hilite
darkThanks
- December 2009
May 29, 2012 at 10:36 am #455349thats what I say: There is no Extended classes input box in my Metadata Options tab.
I installed all extentions, plugins etc, that came with JA-Wall, (no quickstart install). I have a test site to, created by the quickstart pack, there the inut is present.
Please advice me.
PS: I see that in the demo you can also use: grid-double dark no-color
- December 2009
May 29, 2012 at 12:12 pm #455363now my Extended classes showed up. ..
- December 2009
May 29, 2012 at 1:14 pm #455371<em>@napatjo 322703 wrote:</em><blockquote>now my Extended classes showed up. ..</blockquote>
but it disappeard. is the input field only available in CATEGORIES?Wall Crasher DeveloperWall Crasher
- December 2011
- 361 times in 300 posts
June 13, 2012 at 8:30 am #457201Hi napatjo,
Sorry for late reply. ‘Extended Classes’ belong to each article.
Open article in edit mode. Expand the ‘Metadata Options’ section on the right. You will see ‘Extended Classes’ field at the bottom of the section.
Please send me your admin access so I can help you.
This topic contains 9 replies, has 5 voices, and was last updated by Wall Crasher 12 years, 7 months ago.
