  • zanganito Friend
    #181529
    I’m trying to set the Facebook Like Box, but I do not get it and is giving me the following error: “There was an error fetching the like box for the specified page.”
    I already obtained the APP ID
    I put the follow Javascript load code in the header file:
    [PHP]<div id=”fb-root”></div>
    <script>
    window.fbAsyncInit = function() {
    // init the FB JS SDK
    FB.init({
    appId : ‘293241480781860’, // App ID from the App Dashboard
    channelUrl : ‘//www.locofortravel.com/channel.php’, // Channel File for x-domain communication
    status : true, // check the login status upon init?
    cookie : true, // set sessions cookies to allow your server to access the session?
    xfbml : true // parse XFBML tags on this page?
    // Additional initialization code such as adding Event Listeners goes here
    // Load the SDK’s source Asynchronously
    (function(d){
    var js, id = ‘facebook-jssdk’, ref = d.getElementsByTagName(‘script’)[0];
    if (d.getElementById(id)) {return;}
    js = d.createElement(‘script’); js.id = id; js.async = true;
    js.src = “//connect.facebook.net/en_US/all.js”;
    ref.parentNode.insertBefore(js, ref);
    }(document));
    </script>[/PHP]
    created the file channel.php
    [PHP]<?php
    $cache_expire = 60*60*24*365;
    header(“Pragma: public”);
    header(“Cache-Control: maxage=”.$cache_expire);
    header(‘Expires: ‘.gmdate(‘D, d M Y H:i:s’, time()+$cache_expire).’ GMT’);
    <script src=”//connect.facebook.net/en_US/all.js”></script>[/PHP]
    …and put it in the root
    Also placed in the app id in the “Facebook Like Box” module.
    Can you see what I’m doing wrong?
    HeR0 Friend
    #470528
    Hi zanganito
    You should try to use JA Social plugin. It’s working nicely.
    Regards,
This topic contains 2 replies, has 2 voices, and was last updated by  HeR0 12 years, 1 month ago.
