  • plugnplay Friend
    #151440
    I am facing a strange problem in one of my website that is having a java script issue and causing menu not to work in all versions of Internet Explorer.
    The link to the website is and it is using Ja Teline3 and using moomenu.
    <blockquote>http://www.parenthood.ie</blockquote>
    I have tried various solutions and also upgrading mootools to 1.2.1 as suggested in
    <blockquote>http://forum.joomla.org/viewtopic.php?f=231&t=310784</blockquote>
    Also tried turning off joomla core mootools off from front end but that has stopped all modules from working.
    Please try to suggest some solution for the same.
    Thanks in advance.
    Manos Moderator
    #345232
    Did you try with all the supported menus ? For me only the CSS Menu works fine
    Manos Moderator
    #345239
    Just saw again…it happens only in front page and not always, that means that there is a conflict since when the menu is working some other modules aren’t.
    jbricenol Friend
    #345241
    Are you sure that are the javascript or module? I have a problema with facing telline III, the problem was a article pasted from microsoft word. Never use paste from word!!!!.
This topic contains 4 replies, has 3 voices, and was last updated by  jbricenol 14 years, 7 months ago.
