Sherlock
- 2478 times in 2162 posts
April 23, 2008 at 2:27 am #127819Some people had some errors when using JA Teline 2, thus I open this thread to collect those errors which have been resolved for your reference, and I will often update it:
1.Error in Hot Topic module:
http://www.joomlart.com/forums/topic/error-in-my-ja-teline-ii-installation/2.Change menu type:
http://www.joomlart.com/forums/topic/main-menu-2/3. Warning: mkdir(…/…/public_html/images/resized/): Permission denied in /…./…./public_html/modules/mod_janews/helper.php on line 99
http://www.joomlart.com/forums/topic/error-with-teline-ii/4. Error: the XML response that was returned from the server is invalid
http://www.joomlart.com/forums/topic/ja-teline-ii-install-problem/5. Fatal error: Call to undefined function imageantialias() in /home/eugene/public_html/news1/modules/mod_ja_catslwi/helper.php on line 112
http://www.joomlart.com/forums/topic/error-in-ja_teline-ii/6. Tell me again how to see the module positions in this template?
http://www.joomlart.com/forums/topic/tell-me-again-how-to-see-the-module-positions-in-this-template/lasor123 Friendlasor123
- April 2008
January 24, 2009 at 6:54 am #287939Hi.
I have some problem whit JA Quartz………..i cant find a way to give the menu “Hovedmenu” bagground the color green ore pink, i also want to give the headline bagground the same color…….where and how do i change this…like in the demo template…
Best, Lasor123
cinthiapolanco Friendcinthiapolanco
- June 2008
March 9, 2009 at 5:25 pm #295028Hi!
Hello everyone
My Ja Teline II does not recognize the new photos to upload to the server. In the frontpage displays the following warning550 Could not change perms on resized: Operation not permitted
I tried to change the permissions to the folder resize from 755 to 777 but the server returns me the following message550 Could not change perms on resized: Operation not permitted
Someone has an idea how to solve this problem.
Cinthia
ShannonN FriendShannonN
- July 2006
- 172 times in 49 posts
March 9, 2009 at 5:36 pm #295030cinthiapolanco;116578Hi!
Hello everyone
Cinthia
If the server refuses to allow you to change folder permissions then it’s best to contact your host support and get then to change it for you and change your access level so you CAN change all permissions, some budget hosts lock certain areas to ‘save’ customers from fiddling way too much etc 🙂
Give them a yell and see what they say?
Cheers Shannoncinthiapolanco Friendcinthiapolanco
- June 2008
March 9, 2009 at 5:48 pm #295032Ok.
ThanksCinthia
This topic contains 5 replies, has 4 voices, and was last updated by cinthiapolanco 15 years, 10 months ago.
