September 18, 2013 at 2:03 pm #190714
I purchased and installed the JA Wall upgrade so that I may use teh Corner_Stamp module position going forward. After upgrade I could not get corner_stamp position to show. So I thought it may be a caching issue and figured I would try again today. Now none of my blog links work at all, the message I get is: Fatal error: Class ‘WallHelper’ not found in /home/milekey/public_html/templates/ja_wall/html/com_content/category/blog.php on line 23
The site is at FloridaKeysMileMarkers.com if anyone has any ideas I would really appreciate it. I have already submitted a support ticket and am awaiting a response, but meanwhile my site is not fully functional.
Thanks for your time.
Saguaros ModeratorSaguaros
September 20, 2013 at 2:00 am #506410Hi homefront,
Did you get it solved? as I can see your site seems to be working fine now. Let me know if you still need helps.
September 20, 2013 at 3:31 am #506423Thanks for checking, the site is still broken. You have to mouseover the top menu to get at a blog page to see the same error: Fatal error: Class ‘WallHelper’ not found in /home/milekey/public_html/templates/ja_wall/html/com_content/category/blog.php on line 23
ie: http://floridakeysmilemarkers.com/florida-keys-mile-markers/keys-videos
I have a support ticket and am still awaiting a response, if you can help me I will appreciate it very much.
Thanks for looking into it.
September 23, 2013 at 3:04 am #506660Hi
It’s weird since here is what I see in your site:
September 23, 2013 at 3:22 am #506666Thanks, I forgot to post that it got fixed on Friday at 7:10 AM Florida Time by Leo as a result of the support ticket I posted.
Here is what he says fixed it; hoping this may help someone else:
Hi Michael,There is a quitely big update between v1.0.3 and v1.0.9 that is why you got above issues.
– The error with WallHelper in blog.php file, I fixed it by putting below line into templatesja_wallhtmlcom_contentcategoryblog.php file:require_once (JPATH_ROOT.’/templates/ja_wall/template_tools.php’);
– The corner-stamp position concern.
Truly, we just define the corner-stamp position on Joomla category blog layout only. And it works fine now.
http://floridakeysmilemarkers.com/key-largo-florida-keys-top-menu/your-photos-key-largo<< In this menu item, i tested with our default banner. You can replace it with your own banner.
Leo
***********************************************************************************************************************Thanks for following up.
This topic contains 5 replies, has 2 voices, and was last updated by homefront 11 years, 3 months ago.
