7of9 Friend
7of9
- December 2010
- 25 times in 3 posts
February 18, 2015 at 7:56 pm #203922Hi,
After installing the Joomla 3 quick start of the template, I try to open the JA VM Products modules from the back end and I get error:
Fatal error: Class ‘JElement’ not found in /home/xxx/xxx/html/xxx/administrator/components/com_virtuemart/elements/vmelements.php on line 36
I replaced the domain name with xxx.Please advise.
Adam M ModeratorAdam M
- May 2014
- 1271 times in 1235 posts
7of9 Friend7of9
- December 2010
February 20, 2015 at 3:06 pm #560133Hi Adam,
Thanks for the offer, however according to this thread http://www.joomlart.com/forums/topic/create-ja-vm-product-module/ Pavit says that:
This Thread has already opened a support ticket for Jomlart Devs – Ticket ID (PRK-449-61845) so as you can see problem is actually in solution phase and will be solved as soon Joomlart will be again at 100% of dedicated staff, actually it is reduced due to the annual festivitySo it’s a bug they are going to fix soon.
- May 2014
7of9 Friend7of9
- December 2010
March 4, 2015 at 11:03 am #561570Hi Adam,
It appears that there is no ticket to dev team and you are the one who is supposed to resolve the issue.
I sent you a PM with credentials.Thanks in advance.
- May 2014
- May 2014
7of9 Friend7of9
- December 2010
- May 2014
7of9 Friend7of9
- December 2010
March 13, 2015 at 8:20 pm #563009Hi,
Since you are fixing it for J3, you should also consider resolving this blocking issue that lowers the loading speed of the website and blocks page rendering. (You could check it at GTMetrix test.)
The following external resources have small response bodies. Inlining the response in HTML can reduce blocking of page rendering.
Should inline the following small resources:
http://www.–.–/modules/mod_javmproducts/assets/css/style.cssAdam M ModeratorAdam M
- May 2014
7of9 Friend7of9
- December 2010
- May 2014
March 17, 2015 at 10:51 am #563410Hi @7of9,
I have just checked your site with GTMetrix but see that it only take around 1s to load that CSS file. Actually put inline CSS code there would make it’s hard in case you want to use your own code as you will always have to use !important, so we better put it in external CSS file instead.
7of9 Friend7of9
- December 2010
March 17, 2015 at 5:02 pm #563467Hi @adam M,
You are probably right. I have performed serious optimizations on this website and I have managed to make it load in around 2 seconds. I am also working on a guide to explain how to optimize the template, in order to achieve this. I will keep you posted.
Any news about the status of the fix?Adam M ModeratorAdam M
- May 2014
This topic contains 33 replies, has 2 voices, and was last updated by 7of9 9 years, 7 months ago.
