You are welcome
Thank you
Viet Vu
i’ve got the Same problem ?
what is the solution ?
Hi Viet.
Sorry to bother you again, but I got another problem. Now the compoment is not visible in the page, also if I have checked and the plugin is enabled in the correct page.
Could you help me again?
Thanks a lot,
Claudio
did you guys upgrade from 1.6 and then this happened?
<em>@claudiozucca 282637 wrote:</em><blockquote>Hi Viet.
Thanks a lot,
Claudio</blockquote>
May i have detail of your trouble and possible with FTP / backend access for checking ?
i had the same problem but i didn’t install the UDJA plugin
have you the solution
thanks in advance
Stefano
<em>@stefanomind 324883 wrote:</em><blockquote>i had the same problem but i didn’t install the UDJA plugin
thanks in advance
Stefano</blockquote>
Hello stefanomind,
Would you mind get me a few screenshots for more clarifications? Then I shall know what you are trying to achieve.
Right now, I am quite not sure where to start.
BTW, what does “UDJA” mean?
Regards.
This topic contains 22 replies, has 7 voices, and was last updated by Stork11 12 years, 6 months ago.
