September 14, 2015 at 7:53 am #683691
Hi! 🙂
How can I put FavSlider on home page?
jooservices Friendjooservices
- October 2014
- 1245 times in 1121 posts
September 14, 2015 at 7:56 am #683723Hi there
# Which module position you want to assign ?
# What’s favslider module ?Thank you,
Viet Vujooservices Friendjooservices
- October 2014
September 14, 2015 at 7:56 am #748462Hi there
Viet VuSeptember 14, 2015 at 8:12 am #683726I made modul position but it doesn`t show in position options.
I changed code with this one:
<block name=”header” type=”header” main-inner=”1″></block>
<block name=”slideshow” type=”modules” style=”raw” >slideshow</block>—-
Module: FavSlider Responsive Slideshow [mod_favslider]September 14, 2015 at 8:12 am #748465I made modul position but it doesn`t show in position options.
Module: FavSlider Responsive Slideshow [mod_favslider]jooservices Friendjooservices
- October 2014
- October 2014
- October 2014
- October 2014
September 14, 2015 at 9:13 am #683735Not working.
What can I do about it ?September 14, 2015 at 9:13 am #748474Not working.
What can I do about it ?jooservices Friendjooservices
- October 2014
September 14, 2015 at 9:21 am #683736Hi there
I have assigned and bring your module to module position as asked.
But some how your module is not working. Quick check i saw js error.Please consider ask your module provider about this.
Thank you,
- October 2014
September 14, 2015 at 9:21 am #748475Hi there
Thank you,
Viet VuSeptember 14, 2015 at 9:43 am #683739Thank you for your time and help. 🙂
Can you just tell me how can I safely uninstall or remove that and any other modul?
This topic contains 17 replies, has 2 voices, and was last updated by jooservices 9 years, 3 months ago.
