  • netmipl Friend
    #941103
    Hello
    i want to make this http://joomla-extensions.demo.joomlart.com/index.php/ja-k2-filter/2-extra-fields-group on my site but i cannot do this.
    In your example when i choose Laptop category, fields are show, andwhen i change category another show and laptops are hidden.
    When i set it like in a instruction (documentation) i got all fields even if i didnt choose category.
    How i can do this ?
    netmipl Friend
    #941117
    Do you know what i do wrong?
    Luna Garden Moderator
    #941363
    If you set to show more than two categories, the effect while choosing category will appear.
    Could you share your site URL, and admin account here (in private reply) so we can check problem for you.
    netmipl Friend
    #941467
    Mo0nlight Moderator
    #941636
    Hi.
    The group view only support for Vertical layout.
    So you need to change
    Module Layout -> Vertical
    Regards.
    netmipl Friend
    #942023
    Thx, I have 1 more question. How can I hide accordion menu with all options when nothing was choose in category dropdown? Now when i reload page i have always first of the category accordion fields. When i switch them i didnt see which classes are change. I’ looking forward to response
    can I set more than 1 field group to category? OR 1 field for example price for all groups
    everything in http://joomla-extensions.demo.joomlart.com/index.php/ja-k2-filter/2-extra-fields-group (2 extra fields menu). All the problem is that i want to some fields depending on category and the rest will be the same for all categories
    #942087
    You can try this:
    in file:
    modules\mod_jak2filter\tmpl\default.php
    Find for code like bellow :
                    /*<![CDATA[*/
                    jQuery(document).ready(function () {
                        jQuery("#jak2filter<?php echo $module->id;?> .accordion")
                            .accordion({
                                header: " > h4",
                                autoHeight: false,
                                collapsible: true,
                                icons: {
                                    header: "collapsed",
                                    headerSelected: "expanded"
                &lt;/script&gt;
    change to
                    /*<![CDATA[*/
                            .accordion({
                                header: " > h4",
                                active: false,
                                autoHeight: false,
                                collapsible: true,
                                icons: {
                &lt;/script&gt;
    netmipl Friend
    #942359
    thx, i already make the solution about this in css.
    So i cant use the same field for more categories?
    i want to make some filters > models of the car with fields like price, production time etc. I want this fields for more than 1 category. Now I must create every field for each field group.
    #942763
    That was K2 Extra Field workflow, I’m afraid we can’t do anything on this function.
This topic contains 8 replies, has 3 voices, and was last updated by  Luna Garden 8 years, 6 months ago.
