  • erickpaulino Friend
    #201888
    I’m having a problem with the layout of the featured articles in Home. Please see the attached image. You’ll note that when I add a line in the beginning of an article, the introtext converts it into a column, and then it breaks, as you can see in the image.
    How can I fix it?
    Thank you
    1. quebrada
    Hi Erick,
    It due to the custom CSS you added in this file: /templates/ja_magz/css/custom.css
    .blog-featured.av-grid .article-intro, .userpage.av-grid .article-intro {
    display: flex;
    justify-content: space-around;
    try to change it to:
    display: inline-block;
    Have a nice day
    Pankaj Sharma Moderator
    #552230
    HI
    you have added some custom code into your custom.css file , that i causing this issue .
    Go to /templates/ja_magz/css/custom.css
    find this Code:
    display: flex;
    and change the code
    >>> display: flex;
    in to
    display : inline-block; .
    like this code :
    if you want you can also remove the code >> display: flex; .
    it will also fix the issue .
    erickpaulino Friend
    #552261
    Thank you for you both!
    That code was an attempt to justify the intro text, which you can see, didn’t work. Do you have a suggestion on how I can justify the intro text?
    Thank you again,
    Erick
    #552263
    Hi to make the intro text justify . Just add
    text-align :justify in the same code you added above .
    like this
    text-align: justify;
    save and check intro text is now in justify format . >>>> http://prntscr.com/4u5w5r
    erickpaulino Friend
    #552265
    Just perfect! Thank you!
This topic contains 6 replies, has 3 voices, and was last updated by  erickpaulino 10 years, 3 months ago.
