July 3, 2010 at 4:41 pm #152258
Today’s Highlights module does not show the images in the specified size (90×180) as seen in the screen shot. Sometimes when I add more than 2 things in the module, then the third one appears in 90×180, but for the first 2, they appear wither much smaller or larger.
The Featured articles title bar disappeared and can’t get it back. I have installed the template more than once just to get everything back to normal, but I every time I end up losing the above mentioned things.
I would appreciate your help as I am about to publish my site ……. and thanks for reading.
Saguaros ModeratorSaguaros
July 6, 2010 at 9:49 am #349114pls try to disable the ja thumbnail plugin ,and try to disable cache option inside the ja contentslider module and try to test this again
yfi_rnr Friendyfi_rnr
- June 2010
- 3 times in 1 posts
March 17, 2011 at 4:27 pm #381924<em>@tienhc 185454 wrote:</em><blockquote>pls try to disable the ja thumbnail plugin ,and try to disable cache option inside the ja contentslider module and try to test this again
Thanks</blockquote>
I have the same problem (Joomla 1.6) regarding the Featured Articles. I have lost the title badge on Featured Articles like in the image posted by yousuf above and cant seem to get it back anyhow. Your suggestion doesn’t solve it…please help !!Thanks
- June 2010
March 17, 2011 at 8:05 pm #381954<em>@yousufalbalushi 185123 wrote:</em><blockquote>.
.The Featured articles title bar disappeared and can’t get it back. I have installed the template more than once just to get everything back to normal, but I every time I end up losing the above mentioned things.
</blockquote>
I had the same problem and finally solved the mystery 😉Go to Menus–>Main Menu–>Home–>>PAGE DISPLAY OPTIONS–>>
mark the YES option for Show Page Heading and give the page heading as “Featured Articles” or any other.It works 🙂
1 user says Thank You to yfi_rnr for this useful post
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 3 voices, and was last updated by yfi_rnr 13 years, 9 months ago.
Featured Articles & Todays Highlights (problems – rasite)
