October 17, 2009 at 10:46 am #145288
I did a fresh quickstart installation for the JA Mesolite Quickstart package and when the featured products module is disabled, it causes the following error message on the frontpage and the whole site is not accessible due to this error? Is there a fix for this?
Warning: require_once(/administrator/components/com_virtuemart/global.php) [function.require-once]: failed to open stream: No such file or directory in /home/public_html/domainname.com.au/components/com_virtuemart/virtuemart_parser.php on line 74
Fatal error: require_once() [function.require]: Failed opening required ‘/administrator/components/com_virtuemart/global.php’ (include_path=’.:/usr/lib/php:/usr/local/lib/php’) in /home/public_html/domainname.com.au/components/com_virtuemart/virtuemart_parser.php on line 74
mihirc Friendmihirc
- December 2008
- 95 times in 39 posts
October 17, 2009 at 2:08 pm #320789Hello,
Please go through your ftp and check the file permissions. There might be a possibility that the file mentioned by u, i.e. global.php has not been copied due to permission issues.
Regards,
Mihir Chhatre.October 18, 2009 at 6:31 am #320833thanks for the advice, checked the permissions and the file was copied across still same issue.
September 8, 2010 at 3:05 pm #354941<em>@portalworks 149210 wrote:</em><blockquote>Hi,
Fatal error: require_once() [function.require]: Failed opening required ‘/administrator/components/com_virtuemart/global.php’ (include_path=’.:/usr/lib/php:/usr/local/lib/php’) in /home/public_html/domainname.com.au/components/com_virtuemart/virtuemart_parser.php on line 74</blockquote>
I have the same problem with mod_product_categories, how can I fix? Thanks 🙂
Saguaros ModeratorSaguaros
September 9, 2010 at 2:23 am #354984<em>@filomena78 193244 wrote:</em><blockquote>I have the same problem with mod_product_categories, how can I fix? Thanks :-)</blockquote>
The problem happened from missing code to configure path of virtuemart component as following:
[PHP]
if( file_exists(dirname(__FILE__).’/../../components/com_virtuemart/virtuemart_parser.php’ )) {
require_once( dirname(__FILE__).’/../../components/com_virtuemart/virtuemart_parser.php’ );
$mosConfig_absolute_path = realpath( dirname(__FILE__).’/../..’ );
} else {
require_once( dirname(__FILE__).’/../components/com_virtuemart/virtuemart_parser.php’ );
[/PHP]
now, you try to check which modules are display on the page, and open the mod_MODULENAME.php file and check these code ?September 9, 2010 at 7:48 am #355030<em>@tienhc 193305 wrote:</em><blockquote>The problem happened from missing code to configure path of virtuemart component as following:
[PHP]
} else {
[/PHP]
now, you try to check which modules are display on the page, and open the mod_MODULENAME.php file and check these code ?</blockquote>Thanks for your help but I don’t understand what I have to do, sorry 🙁
Where I can find mod_MODULENAME.php? -
This topic contains 6 replies, has 4 voices, and was last updated by filomena78 14 years, 3 months ago.
