midhat Friend
midhat
- January 2010
- 12 times in 1 posts
May 20, 2014 at 3:18 pm #197985Is it possible to add on home page in features-4 position a module “Featured products” instead “Latest Products”.
I have tried, but only appears if the module “latest products”Thanks,
MidhatPankaj Sharma ModeratorPankaj Sharma
May 21, 2014 at 9:21 am #536030<em>@midhat 428258 wrote:</em><blockquote>Is it possible to add on home page in features-4 position a module “Featured products” instead “Latest Products”.
Thanks,
Midhat</blockquote>
Hello Midhat can you provide me screenshot and explain the problem in it .
it will help me to solve your problemmidhat Friendmidhat
- January 2010
May 21, 2014 at 9:30 am #536033Yes, I can.
I’m working on the update of my website and I bought Ja_Decor template. In positions features-4 is a module latest products (mijo shop). I tried to replace that module and put the module Featured products, but unsuccessfully.
No other mijo shop module, except Last items do not appear in that position.Thanks,
Midhat
May 21, 2014 at 9:33 am #536034Please PM me the admin credentials of your site with all details .
I will have a closer lookmidhat Friendmidhat
- January 2010
May 21, 2014 at 10:02 am #536040I sent you PM
- November 2014
- 3854 times in 3563 posts
May 21, 2014 at 11:49 am #536062<em>@midhat 428447 wrote:</em><blockquote>I sent you PM</blockquote>
Please pm me the super admin to access mijoshop component on your site. I shall help you out.
- November 2014
May 27, 2014 at 9:36 am #536806I tried to change directly on your site but I could not access with FTP credentials you provided. You can try step below:
Open components/com_mijoshop/opencart/catalog/view/theme/decor/template/module/latest.tpl file
Find and change
<h1 class="mijoshop_heading_h1"><span class="first-letter">Latest</span> Products</h1>
To
<h1 class="mijoshop_heading_h1"><span class="first-letter">Featured</span> Products</h1>
Let me know if it helps.
midhat Friendmidhat
- January 2010
May 28, 2014 at 9:16 am #536944Yes, but this only changes the title.
I have successfully changed the module and set up random products instead of latest products. What should I do to set the appearance of the module as Latest products?Ninja Lead ModeratorNinja Lead
- November 2014
May 29, 2014 at 10:17 am #537062Yes, you can change this module from Mijoshop module first and then go to Module Manager and load the random module and show it as Latest products module.
midhat Friendmidhat
- January 2010
May 30, 2014 at 9:05 am #537198I did it, but the module looks different. Please check here:
http://emreza.info/test/index.php
The first is the module is Random products, and the second is Latest products. What should I do to random look like a latest?Ninja Lead ModeratorNinja Lead
- November 2014
midhat Friendmidhat
- January 2010
June 2, 2014 at 12:56 pm #537416I sent you PM
- November 2014
June 3, 2014 at 5:08 am #537538<em>@midhat 430263 wrote:</em><blockquote>I sent you PM</blockquote>
Because the random module doesn’t work well with JA Decor template by default.
I just help you to customize it a little bit via components/com_mijoshop/opencart/catalog/view/theme/decor/template/module/random.tpl file
Please check it again, let me know if it helps
midhat Friendmidhat
- January 2010
June 3, 2014 at 10:53 am #537599This is fantastic. Thanks a lot !!!
AuthorPostsViewing 14 posts - 1 through 14 (of 14 total)This topic contains 14 replies, has 3 voices, and was last updated by midhat 10 years, 4 months ago.
